Mahindra 3215 main fuse blows the instant key is turned
   / Mahindra 3215 main fuse blows the instant key is turned #1
whitravis
3215 Mahendra
Unfortunately, it had a low coolant meltdown engine locked. Electrical- main fuse blows instantly when key turned to ON. Have removed all other fuses, still the same. What's next?
   / Mahindra 3215 main fuse blows the instant key is turned #2
Try replacing the main fuse with a twelve volt light bulb. That will limit current so it won't blow while you look for the dead short causing the problem. The bulb will limit current so you won't be able to run anything electrical but should help the troubleshooting process to locate the short.
Terrific advice, will do. Thanks! BTW, your Triumph is one of the bikes in Cyclist magazine I drooled over in high school. Nice one.
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
2020 DRAGON ESP...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
