Mahindra 3525 Broken PTO lever went limp.
/ Mahindra 3525 Broken PTO lever went limp. #1
beachbumrod
San Antonio, Tx
Mahindra 3525
Hello, I have a Mahindra 3525 that I tried to engage the PTO lever and it went clunk and now the lever is loose. It was hard to engage and I read that you can remove the lever by removing the three bolts that hold the lever in housing. I did that yesterday and found the sheered roll pin that was broken. However I don't know it connects to the other type of shaft that engages the PTO and keeps it from going limp, I am just not sure what I need to do. I have added a photo of the the lever with the roll pin any help will be appreciated and thank you in advance.
View attachment 508160View attachment 508161
/ Mahindra 3525 Broken PTO lever went limp. #2
Go to New England Tractor web site. They have a link to Mahindra parts catalog that is for dealers. Mahindra should make this available to everyone. Anyway, your tractor is listed and there is a schematic of the PTO parts. It looks like there is a shifter that goes on the end of the shaft where the pin is. It must have broken off. Hopefully you can get to the insides of your transmission from the top. A similar thing happened to me on a John Deere 850. I was able to access it by taking off a plate on top of the transmission.
Should be an easy fix if you can get to it and the shifter is available.
/ Mahindra 3525 Broken PTO lever went limp. #3
From what I hear those blue pills are good for that limp lever syndrome.
/ Mahindra 3525 Broken PTO lever went limp. #4
P# 000751115R92 your missing the part that the rollpin holds on.. it will have a sleeve that fits over the shaft then the roll pin holds it on... the sleeve has a finger coming off of it that slides the pto collar back and forth.... youll need to fish it out of the trans
goodluck:D
/ Mahindra 3525 Broken PTO lever went limp. #5
goodluck:D
you gona need a new gasket also P# 001233558R2
goodluck:D
Do you know how I would go about getting to it? Can I access it from the hole that the pto shaft and roll pin is in? I looked in there but did not see it
Haha I think I need a beer and a Tylenol:cool2: instead
/ Mahindra 3525 Broken PTO lever went limp. #10
Sorry I just saw this you have to take the tire, fender and floor panel off usually to get to it
/ Mahindra 3525 Broken PTO lever went limp. #11
And yes you go through the hole the shaft goes through
/ Mahindra 3525 Broken PTO lever went limp. #12
I just pulled my lever off a 575 and found broken sleeve. Now I can't get lever lined back up inside. Is there a trick are picture to help reinstall?
/ Mahindra 3525 Broken PTO lever went limp. #13
Flash light and a long punch... have someone turn the PTO by hand very slow at the back of the tractor while you slide the collar.... oh and have you fished out all the broken pieces?
/ Mahindra 3525 Broken PTO lever went limp. #14
you did use the hole the shifter shaft goes in right?
Not the PTO shaft
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
