RockyNY
My 4035 PST had an issue with the F/N/R shuttle lever where you'd have to lift and pull it slightly towards reverse in order to activate the neutral safety switch. It was getting annoying so I decided to dig into it and see if there was an adjustment on the shifter cable. I did find an adjustment, but it's not on the cable itself. Rather, it's on the bracket that holds the cable end, on the transmission end of the cable. You can access from underneath the tractor, behind the fuel tank. The shifter cable sheath is purple, so it's not hard to find. There are two screws that hold the bracket in place, and the bracket holes are slotted. I'll try to get a photo and post it later.
