Mahindra 4110 Rear Brake Boot Replacement
/ Mahindra 4110 Rear Brake Boot Replacement #1
rnds76b
Willimantic, ME
Mahindra 4110 w/ML112 bucket & Husqvarna YTH24V42LS
Have loosened/removed the retaining plate around my 2008 Mahindra 4110 rear brake boot (where the brake rod goes into the rear axle), but don't know how to "break" the rod apart to get the old boot off the rod and the new one on. Anyone done this and have any advice?
/ Mahindra 4110 Rear Brake Boot Replacement #2
The parts book shows the rod, boot, cover plate, and a turnbuckle. How much of that is visible (and accessible) with the boot loose and pried back? A photo or two of what you see might help.
Sometimes it takes my little brain a tad longer to see the light, Harry. As i was reading your post, it just dawned on me that all I should have to do is detach the front end of the brake rod from the lever, THEN unscrew the rod from the turnbuckle to get it off and remove the boot. As the new generation says, "Duh!" Will let ya know. Thanks for "flippin' the switch..." :)
2017 Ford F-550 Bucket Truck - Power Stroke Diesel, ETI 40 Boom, 45 ft Working Height (A61306)
2017 Ford F-550...
8065 (A55852)
8065 (A55852)
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
(20) ROLLS OF UNUSED KJ K1230-10 FIELD FENCE (A60432)
(20) ROLLS OF...
(32) 2"X5"X20' CHANNEL IRON (A60430)
(32) 2"X5"X20'...
UNUSED 2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
UNUSED 2023 VOLVO...
