Mahindra 4500 Cooling System Draining
   / Mahindra 4500 Cooling System Draining #1
Bevo1988
Houston, Tx
Mahindra
I am looking to change the radiator fluid on my 4500 and operators manual says "two drain plugs must be opened. One is on L.H. side of crankcase and one on radiator bottom tank.
Anyone know where the plug on LH side of crankcase is located?
  • 4500 LH-RH View of Engine.pdf
   / Mahindra 4500 Cooling System Draining #2
We have the 4540, it looks like if you take the grille off the front so you can get to the battery it would be on the bottom front left. Our book shows a plastic screw in plug.
   / Mahindra 4500 Cooling System Draining #3
Here's the picture from our book.
Thanks for the reply.
That is the plug on the bottom of the radiator, I saw that plug.
Cannot find the one one the left hand side of crankcase.
   / Mahindra 4500 Cooling System Draining #5
on my jd it was a brass plug at the back of the engine bottom of the cylinders above the oil pan maybe yours is close to that set up:confused3:
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A55314)
2022 John Deere...
2005 SHOPMADE TRIAXLE GOOSENECK (A55745)
2005 SHOPMADE...
2018 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55852)
2018 Chevrolet...
2023 Chevrolet Tahoe FL SUV (A55853)
2023 Chevrolet...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
