Mahindra 5010 Gear (No Cab) Will Not Start
   / Mahindra 5010 Gear (No Cab) Will Not Start
When I put shroud around steering wheel after fixing power steering leak. I noticed that I have no instrumentation. Tractor starts but can't see fuel level etc. I'm going to trouble shoot this since I took shroud off to troubleshoot 'no start' problem. Will update later
Okay.. instrumentation fix was simple. One connector was dangling from wiring harness. Both a 14 pin connector and a 12 pin connector mate with connectors on backside of black panel behind steering wheel. Finally noticed the white slot that mated with the 12 pin loose connector. Fuel gauge works now. Temp gauge will need engine heat to move its needle but no reason to expect it won't. Also put nut on clutch lever bolt that activates clutch switch. Put nut on top and tightened down to keep bolt from moving downward from vibration. If my clutch were this easy I'd be hauling hay all over the farm
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
John Deere 693 Corn Head (A50514)
John Deere 693...
2024 New Holland T8.410 MFWD Tractor (A52128)
2024 New Holland...
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
