Mahindra Considered 2nd Tier?
   / Mahindra Considered 2nd Tier?
. If you want a true comparison though, you should compare the same level of tractors between brands. ;)
All tractors I named in the original post ARE the tractors one would use for a true comparison.
   / Mahindra Considered 2nd Tier? #12
The Kubotas you listed are considered deluxe utility. You need to look at the MX5100 or probably the M5640SU to have a true comparison IMO. The Mahindra 5530 is a utility tractor, but not a deluxe model as the M5040 & M6040 are considered. Doesn't matter to me, just trying to help you compare apples to apples. ;)
Thanks, but the MX5100 compares in size and weight with my old CT335. The 5640sube is a bare bones tractor which even the Kioti DK55 makes it look like a toy, feature wise. I really like the M5140, but at $5K more than the Mahindra, I dont know if I could justify it.
   / Mahindra Considered 2nd Tier? #14
Manhindra is a good tractor and is close or is the number 3 tractor seller in the states now. 5530 is a good/strong tractor also. You might also want to consider the JD 5055D or 5055E. I think the JD might not be that much different in price.
   / Mahindra Considered 2nd Tier? #15
of the ones you listed i would get the kubota m5040 or 6040.let tell about my mahrindra experience .the mahrindra is a basic tractor that would be good for gardening or upkeep around a small farm.i got mine to work with .it now has 700 hours.i have had to weld numerous hitch and front end parts back together. i broke the lever off the hydraulic valve.i discovered you can not buy the lever you have to buy the whole valve.real expensive.i had thought jd parts are expensive,wait till you start buying mahindra parts.i only use the tractor to hay rake,move hay bales and pull a 6 ft disc in the garden.it just does not like being run all day with out something going wrong.a friend of mine has one like mine,he likes it a lot.he only uses it to bush hog a little and pull a box scraper for a few hours at a time.if you to have to have a mihindra,i would recommend you get a used one,for they seem lose their value faster than a jd or kubota.
   / Mahindra Considered 2nd Tier? #16
I am not pushing the Kubota, if anything just the opposite. Just want you to compare equally which is why I had highlighted the M5640SU. I like Mahindra, have 2 of them, both have been excellent machines for me. When a person is looking, they should at least look at all that are available in their area and in the same category. If you are looking at entry level utility tractors, to be fair to yourself wouldn't you want to only look at entry level and not entry level with model A and deluxe with model B? Now if you have a certain price point, say 30k and you just want to get the most tractor for that amount of money, then that is a different deal altogether.
Again, I don't care one way or the other, just trying to help with looking at everything equally. ;)
I'm sorry, but why would you weld anything on a new tractor? I would be all over Mahindra's ***** and get them to make it right. You say they are garden quality tractors, but I know of no garden tractor that weighs just under 3 tons without the loader. Do you know if other owners have experienced weld failures?
OK, lets make that price point $26K, which puts the Kubota 5140 out as the cheapest price I could find was just under $30K.
So at $26K, what is the most bang for the buck?
   / Mahindra Considered 2nd Tier? #18
cowski,
In fairness to the OP let us know which model/yr are you are speaking of that has been giving you problems.
Idaho2
   / Mahindra Considered 2nd Tier? #19
LS hands down at this time. Of course it all depends on where you are located. I am guessing that you can get a U5030 close to your price range. Take a look at what you get, 16x16 trans, 2 rear remotes among other things. I like all the gears myself and would be hard pressed with only 8, but that is just me. You will be hard pressed to beat a 30 series Mahindra, big, tough, heavy and good capacities. How much weight are you looking for? That can make a difference also. Don't let the guys say"oh you can just add more weight" That's right you can, and you can add that same weight to the already heavy machine and make it even heavier than you can ever think about getting the lighter machine. I have my Mahindra 7520 ballasted to were it weighs in right around 12,000lbs. Just about perfect for it. It came from the factory at 7300lbs. Other brand tractors of the same size and hp weigh in at about 5k and then get ballasted. There is no making up that other 2300lbs.
If I were you, I would take a look at EVERY tractor that I could for that 26k and then make a pro and con list for each tractor and then get the one that I liked the best anyway. But at least I would know what was out there and that I had all the available facts that effected my purchasing decision.
Have you sat on any of these tractors that you are considering? Ergonomics would play a huge part in my decision. Before I bought my 7520, I thought that I wanted a New Holland TN75. That was until I sat on one, I did not like how it felt to me and that was the end of wanting that particular tractor. People say, "oh you get use to it". I say why should I have to get use to anything when there may be a tractor that fits me perfect and there is no getting use to anything.
All different ways of looking at stuff and getting to the end decision.
Good luck. ;)
While the LS may in fact be a good tractor. Any brand in which service doesn't exist (my LS guy is also a music store :confused2:) is out.
I do in fact have a big list of specs, prices, etc. That is how I came to Mahindra in the first place. Heck, if Bobcat had a bigger framed tractor, I would be on it in a heartbeat as I loved my CT335. Kioti's upper end DK series is the same as Bobcats non existent size line, but the shuttle is non hydro and I don't know if I am OK with that. I used to love the HST models, but if after 4,5,? years the HST goes out, we are talking major money to fix, which is why I am going to geared.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Ford Super Duty Pickup Truck Bed (A52377)
Ford Super Duty...
UNUSED DIGGIT 72" HYD MULCHING HEAD (A54757)
UNUSED DIGGIT 72"...
2010 Ford E-450 Super Duty Transport Bus (A52377)
2010 Ford E-450...
2020 Dodge Ram 5500 Auto Crane 6406H 6,440LB 3 Ton Mechanics Crane Truck (A52377)
2020 Dodge Ram...
