Oil & Fuel Mahindra Diesel Fuel Recommendation
   / Mahindra Diesel Fuel Recommendation #11
If your supplier has a high turnover then then the desiel fuel you bought would have to ulsc no longer allowed to produce high sulfur
Its sad that I had to buy a tractor to start learning about diesel fuel. :laughing: I will keep buying from my supplier and not think twice.
   / Mahindra Diesel Fuel Recommendation #13
Low sulfer is actually better for your tractor. This government mandated Ultra low sulfer fuel is actually so bad that you better be using diesel fuel conditioner. Truck drivers all do. Mahindra has its own brand that works great. Just like ethanol in gas ruins engines, this new fuel wreaks havoc on seals and gaskets. I think a pint does like 500 gallons. Good luck !
MahindraDon, I agree with you on the ULSD lubricating property. I have run Power Service in the tractor since day one. I use the grey bottle in the summer and the white in the winter. Would not think about running it without some type of fuel conditioner.
   / Mahindra Diesel Fuel Recommendation #15
Truck drivers do not all add conditioners but refiners do add lubricity, etc. Just like they add anti-gel in the winter. The anti-gel additives are cheaper than putting out real No. 1 fuel.
2008 IC Corporation PB205 Bus, VIN # 4DRBVAANX8A506494 (A51572)
2008 IC...
2013 FORD F-650 ROUSTABOUT (INOPERABLE) (A52472)
2013 FORD F-650...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
RHINO / ATHENS  18FT DISC (A52472)
RHINO / ATHENS...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
