mahindra hydraulics not working, Help
   / mahindra hydraulics not working, Help #1
chasminicozzi
okc
Mowed a week ago parked the tractor when i started it loader wouldnt lift... no hydraulics.... 2001 40 horse mahindra.. Any help would be great
   / mahindra hydraulics not working, Help #2
Things to check.
Fluid level, external filter, internal sump filter, air in system, bad pump, leak in suction hose, etc.
Fluid is clean and full . is the pump internal or belt driven ?
   / mahindra hydraulics not working, Help #4
Check the hydraulic quick connects to the loader.
Started it again still have nothing, when I shut it down looking under the back right side of the engine compartment and slow drip started. Mabey this is the pump . Its parked close to the shed I get into to see. Need to raise the bucket to move it, ?
Is there any electronic parts that could keep the pump from running?
   / mahindra hydraulics not working, Help #7
to back up drag the bucket to go forward pry the bucket up and lay a 2x4 or something under it so it won't dig in. Check the linkage nothing has come apart on the end of a control cable what ever you do look for the simple things.
Im going to try changing the hydraulic filter tomorrow, almost has to be something simple as it has never gave any signs of trouble. im looking for a service manual . i appreciate the help. ill let you all know what ends up fixin it.
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
Blue Diamond 103709 (A53317)
Blue Diamond...
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
