Mahindra: Stop painting the engine black. Paint it Mahindra Red.
   / Mahindra: Stop painting the engine black. Paint it Mahindra Red. #1
Mad Mac
Grapeland, TX
Mahindra 5555
Almost every tractor manufacturer paints the engine and running gear the same color as the body. These lighter colors, whether green, red, orange, yellow or blue, make it possible to see what you are doing when cleaning up and working on the tractor. The black engine compartment on the Mahindra makes it difficult to identify the source of leaks or other problems. A person can go blind trying to see in there. Stop using black paint. Mahindra red would be lovely.
   / Mahindra: Stop painting the engine black. Paint it Mahindra Red. #2
You do realize that it is probably a justified reason for black. Black is one of the cheaper paints and red is one of the most expensive paints.
David from jax
John Deere green being expensive has nothing to do with the paint.
   / Mahindra: Stop painting the engine black. Paint it Mahindra Red. #3
Case IH paints running gear and engine black, and only the fenders and hood (body panels) are red. I guess NH does similar but with blue panels. I never gave it much thought until I read this thread, but I do like the way these are painted. It's much easier to repair and paint black if needed.
   / Mahindra: Stop painting the engine black. Paint it Mahindra Red. #4
David from jax
   / Mahindra: Stop painting the engine black. Paint it Mahindra Red. #5
I kinda like the gray (engine/trans/frame/etc.) red body on my the classic MF 135.
   / Mahindra: Stop painting the engine black. Paint it Mahindra Red. #6
Maybe Mahindra paints it black so you won't see the leaks and defects. :cool2:
   / Mahindra: Stop painting the engine black. Paint it Mahindra Red. #7
Well they certainly use paint to hold oil filters and drain plugs on!
   / Mahindra: Stop painting the engine black. Paint it Mahindra Red. #8
White or gray is much better for identifying leaks ...
   / Mahindra: Stop painting the engine black. Paint it Mahindra Red. #10
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2025 JMR 36in Mini Skid Steer Bucket (A55787)
2025 JMR 36in Mini...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
UNUSED 200 AMP 13' JUMPER CABLES (A54756)
UNUSED 200 AMP 13'...
UNUSED JCT HYD AUGER (A54757)
UNUSED JCT HYD...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
