tjc1989
As a youngster I helped (watched) my father replace the babbit bearings in a then ancient sawmill. The pillow block bearings were a cast iron shell that split horizontally and held the babbit insert that was formed by pouring it into the shell with the shaft in place. The old babbit was dug out of the shell and then the shell was reassembled around the shaft and bolted to the bearing support just as if the machine was working. Then the old babbit and a bit of new babbit was melted in a cast iron pot over a charcoal fire and poured into a hole in the top half of the cast iron bearing shell until the shell was filled to the parting line (the center line of the shaft). When the bottom half cooled, a thin wood strip was inserted on top of the bottom babbit to keep the top half from sticking. Then the top half was poured. When it cooled to solid form, the shell was taken apart and the babbit bearing surfaces "scraped" with a spoon shaped knife just a little to provide an oil clearance. Then it was all put back together and tried. If the bearing got too hot, it was taken apart and scraped a bit more to increase the oil clearance.
It was a lot of work, but then the only tools were a wrench to take the bearing apart, the babbit, babbit pot, and the scraper. Not nearly as quick as running down to NAPA, but you could do it all yourself.
Great story. Love to hear how things had to be and could be fixed, rather than replaced. Imagine the stories your grandfathers could tell of the maintenance and repair of their World War II experiences in the field on remote islands in the Pacific on planes, tanks, jeeps, etc. They couldn't just run down to the local parts store for a replacement part.
