Making concrete porch slip resistant
   / Making concrete porch slip resistant #11
Adding non-skid is a very common practice with boats. There are a number of products besides sand and various coatings to hold them. Look into how it's done on boats to get some ideas.
   / Making concrete porch slip resistant #12
Get a concrete guy to grind the porch down with a circular large area disk grinder to remove the slickness, and leave a swirl pattern on the surface.
This is a good idea. Add some texture to the surface. Do it once.
   / Making concrete porch slip resistant #13
ITs expensive, but something like nature stone flooring?
another question - My porches were sealed when the house was built in 2006 - How often do they need to be sealed OR do they need to be sealed?
Thanks for all the suggestions.. Keep them coming if you have them..
Ill be googling using the stuff you have mentioned already..
thanks
brian
   / Making concrete porch slip resistant #15
If they are slippery because the concrete was polished ( burnished ) when laid I would think that just spraying it with metricate acid then washing it off would fix the slippery problem unless you would like to paint it.
   / Making concrete porch slip resistant #16
Another option. (which I did at my entrance way)
I used epoxy based tile cement (mortar) and laid nice non slip 12 x 12 tiles.
Created a snazzy entrance way and solved the slippage problem.
About 7-8 years and looks great.
2012 SHOP BUILT  TANK MANIFOLD (A53843)
2012 SHOP BUILT...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2015 CASE 580N (A47477)
2015 CASE 580N...
PALLET OF SCAFFOLDING (APPROX. 12 PC) (A52706)
PALLET OF...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
