bcarwell said:
I have a Kubota 7500 and a new Middlebuster from Tractor Supply. Used it for the first time today and the deepest I could make it dig was about 8 inches with the 3PH lowered all the way.
Could somebody tell me how to get it to go lower ?
Thanks for any help.
Bob
Seems we are getting two opinions on this post. Some think that changing the angle, or having TnT would be an advantage to solving this problem, but if I have read the original post correctly, the problem is simply that the lower arms won't allow the middle buster to go deep enough, dispite the angle, dispite the type of dirt/mud/rock/sand that it is being pulled thru. Yes, doing these things would help if he wasn't already at the bottom of his 3pt hitch travel, but he is, and although there are several ways of fixing the problem, the ultimate need will be to extend it some way or other without getting it too long. Too long will cause the problem of not getting it out of the ditch when you are finished, dragging the ground in route to the area to be trenched.
An interesting way to have both full depth and be able to retract it far enough, especially with smaller tractors would be to cut the main vertical bar and add a slip joint, using a couple of drilled holes to be able to raise and lower the digging tip by changing the position (which hole the pin is in).
It is actually an easy fix.
A more complicated way would be to add a hydraulic cylinder to the shaft and raise and lower it (past the 3pt arms available travel). This would allow you to get to a depth controled by how much hp and traction your tractor has, and approach a point where parts break if you hit something immovable below ground.
For those members that are fabrication oriented, modifying a reese hitch from a p/u truck by welding pins on a center plate at each end of the square 4" frame, allowing it to spin from a horizontal position (where you could use it to pull trailers) to a vertical position, where you could slip a 2x2 square tubing in it with the correct tip. A top link attaching point would need to be fab'ed to hold it in the correct position, but since it would be compression, it wouldn't need to be that high up.
David from jax
