Making oval holes round.
   / Making oval holes round. #11
OK, here's my plan thanks to several of you. I'm going to round up the hole first with a step drill. I've ordered a 5/8" bridge reamer to complete the process. Finally, I'm going to weld in some shims per the attached to take the load off the pin. This should result in a permanent fix.
I am not saying your plan is not a good one, but I am just asking a question. If the added shims are going to bear the load front and back and keep from egging out the hole, and it looks like they might do just that... then why bother with repairing the existing hole to start with? I know you wanted to go to a 5/8 pin, but if the 1/2 inch pin is just now holding the shank from falling out, and the shank is now in a "cramp" with the shims and cannot move forward or backward... I was just wondering why?.. Not saying not to do it, just wondering...
James K0UA
James K0UA
Because I'm retired and NEED something to fill the time! ;) ;)
What better than working on my tractor.
   / Making oval holes round. #13
Got it!:thumbsup:
   / Making oval holes round. #14
What I generally do is use a 1/2" od pipe inserted into the original hole location. Then fill the gaps with weldment and drill out the pipe (which is round so the drill doesn't buck).
   / Making oval holes round. #15
James K0UA
Thanks for asking that question, so I didn't have to! Boy did I like the answer!:thumbsup:
   / Making oval holes round. #16
I would ink it up, take a circle template and scribe your 5/8 hole. Then take a die grinder and a burr or grinding wheel and grind it to a circle again. I'm thinking 5-10 minutes per hole and it will be perfect. You could leave it a little heavy and finish it with the drill bit but I'd probably just finish it with the grinder. Location should be good enough too because its wore the same on both sides. If you don't have a die grinder then use a drill with a grinding wheel in it and finish it with the drill bit.
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A54313)
2016 INTERNATIONAL...
Wright Sentar (A50120)
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
2020 NISSAN Versa Sedan (A53424)
2020 NISSAN Versa...
