Man up
   / Man up #11
Yeah, I'm rather fond of my x748se as well. Not that I wouldn't like a 1026R.....
It's really hard to beat the comfort, maneuverability, and ride on the 748SE. It's a heck of a mower. I also use a 54" blade for small snows where the L3400 blower is overkill.
I'm sure the 1026R is really nice for other things but would be a bit too small for my needs for loader work or ground engaging.
I hope we get rain again so I can mow. It's been 6 weeks with no mowing here.
   / Man up #12
ccsial said:
Problem is....I would have an inferior tractor to my X748SE for mowing. The ride and handling on a 748 is not matched on a 1026.
The 748 could probably be done with a needle point if someone younger than me did it. It also sounds like you had to buy a different gun than I have. There are no panels to remove on a 748. The ground down fitting is fairly easy to do. I can't get enough pressure on the needle point with my old arthritic hands.
I thought the topic was "manning up" in regards to the intermediate driveshaft? My suggestion is based only intermediate driveshaft serviceability. You are correct, the R is severely inferior to those machines in most other aspects of owning operating.
   / Man up #13
So you think "manning up" means to trade your unserviceable inferior tractor for a 1026R. That really was a useless comment to start with.
   / Man up #14
Do all 2305's have these fittings. I have a 2011 and after reading about this issue looked for mine and could not find them. So either I need to look harder or don't need to look at all. Please advise
Look harder, all 2305's have the hidden zerks. I use a needle point on an air grease gun to grease mine. Not fun.
   / Man up
My tractor has sealed u-joints on the front wheel assist drive shaft. I don't understand why the u-joints are sealed on it and greaseable on the much harder to get to engine to transmission drive shaft. Maybe rpms are much lower on fwa shaft.
   / Man up #16
You're too sensitive about your GT! I'm not the one who started off the inferiority. The point is: in an age of "non-serviceable" and "lifetime lubricated" drivetrain componets, there is hope with Deere. From all accounts, the new SCUT design offers increased ease of servicing your intermediate shaft. Wish I could say the same about the rest of the equipment in my life. For example: google checking, or changing ATF in a Pontiac G8 to see what I'm up against.
End useless comment.
   / Man up #17
Trade in your 2210s, 2305s, and X748ses, on a 1026R. A standard tip works on the rear joint, and a needle works on the front.
I thought that was sarcasm at first but I guess not.
BTW: The grease fitting on our X720 on the drive shaft back near the tranny is accessible with a reg. pistol style grease gun with a flex hose if it's in the right position, no grinding or needle greaser. It appears there's very little movement in that U-Joint so it shouldn't need a lot of greasing. I may be wrong but I don't think it's mentioned in it the manual, we found it by accident.
   / Man up #18
That's how I first took it. I don't like smart alec remarks. But, I'll give this one the benefit of a doubt.
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
Ammco Brake Machine (A53424)
Ammco Brake...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A55218)
2019 Energreen EVO...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2018 Caterpillar 308E2 CR Midi Excavator (A52377)
2018 Caterpillar...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
