Manure buckets, which one do you recommend?
   / Manure buckets, which one do you recommend? #1
Sean2202
CT
Kubota L305DT
Greetings,
Looking to get a manure bucket in the future for my father in laws farm. Currently he has a Yanmar lx490 tractor with skid steer coupler. His barn yard is fairly large for winter cow feeding and has about 60 head. The manure and hay mixture gets a good few layers on it before it is cleaned. He does not have third function. Rear tires are ballasted.
What Manure buckets or forks do you have or recommend? Parts availability if needed and strength of steel bucket is also a factor. Can the tines be replaced easily if they become damaged or bent? Also I do not want a bucket that all the material falls through the forks. This material is pretty well packet so I do not see that as a factor.
Thanks for any input
Sean
   / Manure buckets, which one do you recommend? #3
If moving old hay and manure I would get a replaceable round tine, long bottom L grapple.
Any Grapple with tied together tines tends to push the hay instead pierce into it so it can be removed. We don't have cattle- but do have horses that do produce a lot of waste hay and manure🙂
We also are able to use this style grapple to move and stack large 1200-1500lb square hay bales.
   / Manure buckets, which one do you recommend? #4
Worksaver makes a nice manure fork.
2011 John Deere HPX Gator 4x4 Utility Cart (A44572)
2011 John Deere...
2025 KJ K4230-T UNUSED Metal Storage Shed (A47484)
2025 KJ K4230-T...
Kivel 48in Forks and Frame Tractor Attachment (A44571)
Kivel 48in Forks...
10 Gallon Antifreeze Tank (A47369)
10 Gallon...
6Yd Dumpster (A44571)
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A44572)
2008 Ford F-350...
