Marvel-Schebler TSX-458 carburetor choke shaft seal
   / Marvel-Schebler TSX-458 carburetor choke shaft seal
Don't know how much vacuum the choke bore sees, but for less than a buck, the o-ring is cheap insurance.
   / Marvel-Schebler TSX-458 carburetor choke shaft seal #12
ahem, insurance against what exactly?
A sloppily bored carb body?
Unfiltered air going through the carb and into the engine (i.e. sucking in dirt/dust).
   / Marvel-Schebler TSX-458 carburetor choke shaft seal #14
Okay fair enough I guess.
The shaft shouldn't be loose enough to worry about it though....... even if the air filter isn't maintained.
That said, as it isn't on the vacumn side of the carb operation I just wanted to know the thought process behind putting a seal on a choke shaft.
Thanks.
During a naturally-aspirated engine's intake stroke, the highest pressure is in the atmosphere. Anywhere along the intake path, the static pressure is lower because you trade pressure for velocity. So if you had any holes/leaks along the intake path, it would want to suck in unfiltered air (or rather, the higher pressure in the atmosphere would push it in).
   / Marvel-Schebler TSX-458 carburetor choke shaft seal #16
Heres what I don't understand,
Why does the choke shaft even need a seal?
I understand a throttle shaft needing a reasonable seal, but a choke shaft? As long as the choke is free to do it's thing and isn't falling apart what is the big deal?
If it's too sloppy, sleeve it, put a little grease on it, keep it lubed now and then. It's not like it has to seal against a great vacumn pull. And in fact it designed to open a bit with some vacumn.
What am I missing?
seal out dirt maybe?
   / Marvel-Schebler TSX-458 carburetor choke shaft seal #17
That's why it's called a vacumn. And it's all under the throttle plate side.
Other than from the volocity column of the air flowing from the other side of the throttle plate via the air filter there is no vacumn, ergo you get a metering of gas through a sized jet set in the middle of the column.
But there is no vacumn per se on the atmospheric (the filtered) side of the throttle plate.
   / Marvel-Schebler TSX-458 carburetor choke shaft seal #18
Myself, I'd worry more about bad sealings between the air filter and the carb.
If the choke shaft fits so loose as to be a concern, I'd drill the carb body and sleeve the shaft properly.
Randy
2017 Jeep Wrangler (MPV), VIN # 1C4BJWDG2HL674841 (A51572)
2017 Jeep Wrangler...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2004 JOHNSTON STREET SWEEPER (A52577)
2004 JOHNSTON...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2020 KENWORTH T680 SLEEPER TRUCK (A52576)
2020 KENWORTH T680...
2022 ATLAS XAS188 AIR COMPRESSOR (A52472)
2022 ATLAS XAS188...
