Maschio Jolly 2016 5 ft finish mower, Mahindra branded
   / Maschio Jolly 2016 5 ft finish mower, Mahindra branded #1
John Fitzgerald
Elkins, Arkansas
XJ2025H same as NH Boomer 24
I recently purchased this mower used, and I found some side play in the spindles, which may indicate they need to be rebuilt with new bearings. Has anyone on here ever rebuilt spindles on this model mower? They have a 4 bolt square pattern housing. A thin 25 mm slotted self locking nut is on top of the pulley, and it uses a 18mm x 1.5 nut to secure the blade. The spindle shaft has to come out from the bottom. There is a grease fitting in the top of the shaft.
   / Maschio Jolly 2016 5 ft finish mower, Mahindra branded #2
The spindle and bearings are replaced as a unit. You can send MASCIO an e-mail with the mower serial number and I am sure they will send you a pdf of the owners manual to help you.
I have some new bearings on hand from Brooks Ag Supply. Supposed to be able to just replace the bearings. I was wondering if anyone on here has had that experience. Thanks.
2015 PJ TRAILER  16 TANDEM AXLE UTILITY TRAILER (A52472)
2015 PJ TRAILER...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
2001 CHEVROLET TOW TRUCK (A52472)
2001 CHEVROLET TOW...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
Tradewinds Power Unit (A50120)
Tradewinds Power...
