MASSEY 2360 SNOWBLOWER
   / MASSEY 2360 SNOWBLOWER #11
DEWFPO said:
The OE shear bolts have a chamfer cut around the circumference of the bolt. An intentional weak point. When I snapped one of the auger shear bolts I didn't even realize it until I noticed that I was pushing snow with the one side.
DEWFPO
The OE shear bolts do have a chamfer cut which I managed to shear in the first 1/2 hour of operation of the new blower. When I went to the dealer to get a replacement, there were none in stock so he handed me a grade 2 bolt and told me if I needed more the local hardware store was right down the road. When I asked if they would work as well as the original, he gave me a funny look like I just arrived from some other planet.
So I have sheared a couple of the bolts I mentioned with no ill affect to the blower (except for me being out of commission) and now I have plenty of replacements.
Since you mentioned the auger shear bolt, I checked them after replacing the impeller shear bolt and all was good.
bobzap said:
...About the filled tires, do they crush lawn areas bad when you run across them?...
What tires do you have? The loaded ag tires do have a tendency to leave their mark when mowing (which is what I have). I ended up buying a set of turf tires (not loaded) for the mowing season because my yard can get pretty soft at times. I did take my 2300 out of the mowing business though and was able to get a good trade on a riding mower with the MMM and the turf tires.
Come on snow.
   / MASSEY 2360 SNOWBLOWER #12
I'm running unfilled AG tires. The grass/soil I cut never has enough water in it to get mushy so even though the tires leave their mark on the flattend grass, within a few hours you can't tell. I need the aggressive AG tires to be able to snow plow and climb the slopes around here. I used to have a mowing tractor with turf tires and often I found myself spinning the tires on the slopes and it was useless to plow. I hardly ever have that trouble now with the AG tires.
DEWFPO
Thanks again guys. I have the unfilled turf tires. I got those because of the lawn I have to cross to get to pending projects. So do most of you leave the BH off if you are not using it?
   / MASSEY 2360 SNOWBLOWER #14
I leave the BH off if I'm not using it so the 3 point is available plus no need to have the added weight bouncing around back there. And I like the R4 tires on mine for a good combo for turf and work. The local dealer now orders most of his 2300/2310s with R4s for that reason.
Doug
40' CONTAINER (A52706)
2011 Hyundai Sonata Sedan (A56859)
2011 Hyundai...
2020 DRAGON ESP...
2011 Jacobsen T-700 Reel Mower (A56859)
2011 Jacobsen...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
20ft Driveway Entrance Gate w/ Tree of Life Design (A57454)
20ft Driveway...
