Massey 4225 trouble with fwd disengaging
   / Massey 4225 trouble with fwd disengaging #1
brucetheyak
mosinee, wisconsin
massey 4225
I have a 1999 Massey 4225 that goes into four wheel drive perfectly with the touch of a button, but getting out of 4wd is another story.
It does not disengage as it should, taking as long as a quarter mile on a paved road before it disengages with a loud bang, and then the tractor rolls nicely in 2wd. Until it disengages the tractor feels as if it is working against itself, with practically no coasting/roll when I step on the clutch.
I have tried going a few feet in reverse to unstick whatever is stuck holding it in 4wd, but no luck.
Does anyone have any ideas on this? Thanks.
   / Massey 4225 trouble with fwd disengaging #2
Hi. Welcome.
Has there been any change in tire size? I.e. low tires or changed size?
I am not familiar with your tractor. It sounds like the shift is electrical. Is the solenoid working properly? Check any linkages for binding.
Actually yes, I did replace all 4 tires. I thought they were all the same sizes as the old ones.
I think the solenoid works, because when it disengages, it does so with a pretty hefty bang - as if it were stuck, but finally let loose. The 4wd indicator light goes off when the disengage button is pressed, even though it is still in 4wd.
Regarding tires - is there a ratio that they should be at to each other that I could check by measuring the tire circumferences?
   / Massey 4225 trouble with fwd disengaging #5
Look under the "dimensions" tab on the attached link to see your proper tire size. Your owner's manual should have it as well
TractorData.com Massey Ferguson 4225 tractor information
I NEVER get on pavement without first taking the tractor out of 4WD while on dirt or grass. There needs to be some give or the axles will mechanically bind against each other on any solid hard connection 4WD system
I usually do too, but sometimes forget before I get on the road. Let me see what happens when I switch it off on soft ground.
   / Massey 4225 trouble with fwd disengaging #7
G'day try reversing and turning from side to side at the same time sounds like the 4wd is loaded up this may help it dis engage
Jon
   / Massey 4225 trouble with fwd disengaging #8
You can also use your FEL to raise the front wheels off the ground to release any tension between front and rear axles.
Tafe 45DI (A53317)
Tafe 45DI (A53317)
NEW Fork Extensions (A59000)
NEW Fork...
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
