Massey Ferguson 1250 - bent stabilizer link/check chain stabilizer
   / Massey Ferguson 1250 - bent stabilizer link/check chain stabilizer #1
artcarneyagr
Benton, KY
I managed to bend the threaded portion of my stabilizer/check chain. Is there an aftermarket one out there that would easily replace the stock one?
It's the part circled in yellow in the picture:
   / Massey Ferguson 1250 - bent stabilizer link/check chain stabilizer #2
Yep, Tractor Supply sells them. You need to measure and make sure the range of adjustment is compatible for your 1250. Eyeball says yes. I had the same issue with a Kubota and the TSC unit was not a compatible length.
Also I have had some success straightening those threaded rods. Clamp between two scraps of 2x4 to preserve the threads and use a vise. Use nuts in the bent rod where you can get them on. Take advantage of the threaded turnbuckle too. Find a 4ft piece of pipe that will just clear and go over the rod assembly for bending leverage. Just keep fiddling with it until you find a way to unbend it. I advise against heat.
   / Massey Ferguson 1250 - bent stabilizer link/check chain stabilizer #3
Any major tractor/farm supply should have one ... All you need to know is the "length"...
   / Massey Ferguson 1250 - bent stabilizer link/check chain stabilizer #4
if not actually snapped can you heat, straighten, retemper then clean up threads?
agco parts lookup
couple models (serial # split it looks like) so maybe able to find part number. if I am right its part # 3702554M1 listed under (oddly) trailer hitch linkage section item # 19
Is 19 just the shackle, or the whole assembly? Item 15 or 16 would be the part that's bent, I can't remember at the moment which threaded end is bent, but it's definitely either 15 or 16.
   / Massey Ferguson 1250 - bent stabilizer link/check chain stabilizer #6
19 was just the end threaded shackle think the other 2 pieces were about same price IF I looked up right model number.
The diagram looks correct. I may have to go to my local AGCO dealer I guess and see if they have it, which is unhandy, but such is life. Drives me nuts I can't just order online from somewhere.
I did find this part for about $50, it says it's for 24"-27" of length, I'm currently using about 14" of length +/-2", I'm thinking maybe I could cut off 3 or 4 links of the chain to get the correct length to make it work:
2007 Freightliner B2 School Bus (A55852)
2007 Freightliner...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
2005 Honda Accord LX Sedan (A55853)
2005 Honda Accord...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A55851)
1991 Grove RT740B...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
