Massey Ferguson 1735E / shibaura n843t-f Electronic Throttle
   / Massey Ferguson 1735E / shibaura n843t-f Electronic Throttle #1
massey_viktor
MF 1735E
Hello everyone, first post here. I have a MF 1735E with shibaura engine, and it has the electronic throttle that I've been trying to figure out. These motors have a mechanical pump, and from what I understand that's really the only thing that's controlling the throttle on the diesel engine. Is that a correct assumption?
Looking at the diagrams for this tractor, I was able to spot these 2 items, Linear solenoid and a sensor for it. I believe I found the sensor on the tractor, and now I am puzzled where the actual linear solenoid is, and if it's simply the same fuel shut-off valve doing the purpose of throttle control in a closed feedback loop with the sensor.
Ideally i expected a servo of some kind, but with this solenoid it could work as such:
- You change throttle lever, that changes input to ECU, ECU then sets expected throttle and applies voltage to Linear Solenoid while the sensor is providing feedback, it removes voltage once it reaches the expected throttle.
Product Rectangle Font Parallel Number
Or am I overthinking it and there's a servo hiding somewhere?
The main idea here is to bypass the electronic throttle and allow for manual control of the engine speed.
CASE 90XT SKID STEER (A52705)
CASE 90XT SKID...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
UNUSED DIGGIT 6'5"-10 DRAWER, 2 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
2012 JCB 930 ROUGH TERRAIN FORKLIFT (A52705)
2012 JCB 930 ROUGH...
