Massey Ferguson 1958 FE35 hydraulic oil??
   / Massey Ferguson 1958 FE35 hydraulic oil?? #1
Raymond Gouge
Massey Ferguson FE35
Hello everyone,
I have an old 1958 Massey Ferguson FE35 4cyl Diesel and in the original manual it states that the hydraulic fluid is straight mineral gear oil, sae 90 above 50 F and sar 80 below 50 F. Now that we are in 2011 times, what brand of hydraulic fluid is compatible with the 1958 manual??
Thank you for your help with this
   / Massey Ferguson 1958 FE35 hydraulic oil?? #2
napa sells 90wt gl1 oil in a 5g pail as part number 65-205
you could use an 80w90 gl5/mt1 gear oil that was yellow metal safe as well.
that scotch yoke piston pump was made to pump heavy gear oil. it's the same pump in the belly of a ford 9n... many people have swapped fords over to the thinner utf oils that appear to be more like a sae 30 oil. ford spec m2c134d
most fergy owners I talk to don't like the swap to the thinner oil and really do like the heavier oil.
soundguy
   / Massey Ferguson 1958 FE35 hydraulic oil?? #3
I have to 1957FE35 Massey Ferguson .One gearbox dip stick is 2" longer then the other .what is the right amount of oil? Thank you cockley
2013 UTILITY VS2RA REEFER TRAILER (A54607)
2013 UTILITY VS2RA...
2015 FORD F350 SERVICE TRUCK (A51406)
2015 FORD F350...
2008 Chevrolet Impala Sedan (A53424)
2008 Chevrolet...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2020 Steiner 450 Slope Mower (A54865)
2020 Steiner 450...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
