Massey Ferguson GC2610 TLB Battery problem, need help.
   / Massey Ferguson GC2610 TLB Battery problem, need help. #1
Nolin harley
2013 Massege furguson gc2610 TLB
Bought a new battery for my 2013 MF GC2610 and after installing the battery, battery light stay on and after 2 or 3 times of using the tractor, battery dies. Seen a youtube video that said pulled the ground wire off while it's running and if it stayed running it's not the alternator. Any idea would be highly appreciated, what else can i look for. Thank you in advance.
   / Massey Ferguson GC2610 TLB Battery problem, need help. #2
Sounds like your alternator is not putting out.
Lifting either battery cable while an engine is running is asking for problems.
Just use a voltmeter and check your voltage while at rest and running.
But, I expect your alternator or wiring is bad.
   / Massey Ferguson GC2610 TLB Battery problem, need help. #3
Fully charged good battery should test 12.6-13.2 volts at rest. Proper operating alternator should show 14.2 volts at battery after warmup with engine running.
It doesn't show 14.2volts
Thank you very much, will check.
   / Massey Ferguson GC2610 TLB Battery problem, need help. #6
Nolin when you checked the voltage running did it show 12.6-13.2 volts? If so your alternator is not recharging your battery. Possibly a wiring or voltage regulator problem, or bad alternator if regulator is internal. The regulator monitors battery voltage and directs current to battery when needed.
It only show's 12.something. I do think the voltage regulator is in the alternator. Thank you.
   / Massey Ferguson GC2610 TLB Battery problem, need help. #8
When alternators first became common, most shade tree mechanics knew that you should not disconnect the battery while the motor is running. There was a high likelihood it would fry the alternator. Don't know if that has changed.
   / Massey Ferguson GC2610 TLB Battery problem, need help. #9
I would check wiring from alternator to battery including grounds. If that all is good probably time to replace alternator or have it rebuilt.
2003 Ford Crown Victoria (Police), VIN # 2FAFP71W93X164893 (A44391)
2003 Ford Crown...
2016 Ford F-550 16ft Flatbed Truck (A44571)
2016 Ford F-550...
2014 Ford Explorer AWD Sedan (A44572)
2014 Ford Explorer...
1992 Case 621 Articulated Wheel Loader (A44571)
1992 Case 621...
Year: 2003 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: (A44572)
Year: 2003 Make...
2011 VOLVO VNL VNL64T300 DAY CAB (A43003)
2011 VOLVO VNL...
