Material to resurface a landing/deck
   / Material to resurface a landing/deck #1
SylvainG
Platinum Member
South West, Qc
Kioti LK30
So I have a 4'x8' landing/deck when going out from the solarium made up of pressure treated plywood that was installed 17 years ago. It was stained as well but with the years and salt, the top layers are starting to delaminate. Because I didn't think ahead when I built it, changing it would mean dismantling the railing as well as the siding on two walls to take it off and put a new one on.
So I'm looking at alternative. The remaining layers are still strong and doesn't feel spongy. Is there a material that is not brittle (it's wood so it does bend a bit) that I could pour over the plywood that would strengthen it and prevent the remaining layers from de-laminating? It has to be able to sustain -35C to +35C (yeah, temperature fluctuate quite a lot here during the year) and tolerate salt.
Thanks!
   / Material to resurface a landing/deck #2
Can you just put down PT deck boards over the plywood? Jon
Case 1030 Case Rear Wheel Weights (A47484)
Case 1030 Case...
Pump (A47484)
Pump (A47484)
2016 Ford F-450 Crew Cab Mason Dump Truck (A44571)
2016 Ford F-450...
2025 KJ K0520 UNUSED (5) Wire Mesh Fencing Rolls (A47484)
2025 KJ K0520...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A44572)
2021 Ford F-150...
Swict 84in Bucket Skid Steer Attachment (A44571)
Swict 84in Bucket...
