Materials Storage Racks
/ Materials Storage Racks #11
I ringed our pole barn 40x63 with used pallet racking and steel mesh decking. Mainly 42" deep 8' & 10' uprights, 6-8-10 wide cross beams. Freestanding on the concrete floor. Depending on cross beams each shelf can carry 2K-5K lbs. I put the lighter stuff up high & heavier stuff dozer engine (3 cyl) dozer transmission etc down low. Implements & wheeled stuff park under bottom shelves to maximize floor square footage. Got a couple of pick up loads of used wood pallets. Everything is on pallets so easy in & out, misc lumber bits are in boxes on pallets.
Changing config & shelf heights to adapt for different things is a snap!
Racks have been up for 2 years & still cannot think of anything better.
Last point the decking is not solid surfaced so varmits are less likely to try nesting as compared to the old wood & plywood shelves.
That rough cut once dried out makes good work bench structure.
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
2016 FORD F-450 (A60736)
2016 FORD F-450...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
10222 (A56858)
10222 (A56858)
