Max 25 HST randomly blows 10 amp fuse for alternator,glow controller,turn signal etc.
   / Max 25 HST randomly blows 10 amp fuse for alternator,glow controller,turn signal etc.
Hi Guys,
I will check the seat even though the schematic shows its controlled by the fuse below the one that blows.
I discovered a few more anomalies this morning while troubleshooting the problem. Again it only blows while operating. Don't know if this means anything but I discovered if I pull the fuse while tractor is running it will keep running. So, I decided to put my ammeter across the fuse block contacts. (I'm not sure why) When I do this the glow plug indicator lights up and the engine slows down. I have no idea if that means anything.
I'm going out now and check the seat switch since it's a known issue regardless of what the schematic shows.
Thanks for all your help. I'll update you a little later.
2018 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2018 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2004 Delta Spread-Axle Gooseneck Trailer. 20ft+5ft. (A56438)
2004 Delta...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
