Max 26 front bucket weight ?
   / Max 26 front bucket weight ? #11
Yes I think it is 20mm pins either way that makes it a more complicated fit. Before you swapped cylinders by chance did you try raise system and relief pressure? I see you used a washer to shim. Was that post cylinder swap or before? If before was there a noticeable difference?
2 tons lift on the L39? Good grief that things in beast mode.
The washer raised the Pressure to about 2300 psig, I dialed back the relief on the loader to 2150-2200 PSI, about 100 psi over spec.
That got the loader lift feeling like it was actually the 1400 Lbs Mahindra states in their specs. The 45mm Lift cylinders are a large as any tractor you will find that size.
The curl force just did not match what the loader would lift. Like you stated, drive into a pile and it would not curl the bucket, unless you backed out, not just a bit, but a lot.
I'd say the ideal match would be 1.5" Curl cylinders, up from 35mm. As the Rod is 25mm, there is only a 5mm annular area acting to curl the bucket.
The 40 MM cylinders from the 1526 loader are slower acting, especially in the dump mode. Still I consider the trade off in my favor.
The Loader and 3pt hitch capacity on my Max are as much as the tractor's frame can handle, and I'm sure an abusive operator would damage the tractor. The Max is small enough to get into Paddocks, Sheds and Barns, while still big enough to do the land engagement and loader work on our small farm. a real labor saver to be sure. Other than precision close quarters loader work, the shuttle shift is excellent, as it takes on hills and roads well.
The Max Shuttle is much better shifting gears than the 3X2 straight gear old Kubota I had. Other than snow removal, firewood, heavy pallets, and landscaping work, my L39 and excavator can have an easier life as the Max is the go to "chore tractor".
   / Max 26 front bucket weight ? #12
How to increase the Max 26 FEL capacity for SSQA /Pallet Forks, etc.
Thinking a little more about this it is not so bad.
Use the Rods from your existing Max26 cylinders.
Buy just the Gland and, piston and seals kits from the Curl Cylinders of the 1526 Loader, with 40 mm bore.
Mahindra PN is KMW31502148 for the entire cylinder.
Have a hydraulic shop fabricate a new pair of tubes, duplicating the length of the Max26 Cylinder tubes.
Cut off the tube pin ends on the existing Max26 Tube cylinder weld them to the new tubes and assemble the "new cylinders."
The new cylinders should fit perfect and you should have more than 2,000 lbs of Breakout/ curl force.
Glands, seals and pistons are also available from:
Hydraulic cylinder repair seals and kits-Hercules Sealing Products - Hydraulic Seals and replacement cylinders for construction and many other heavy equipment industries.
they have good prices, but for a few dollars I'd stay with the Mahindra parts particularly the Piston, just for proper fit.
Re: How to increase the Max 26 FEL capacity for SSQA /Pallet Forks, etc.
That sounds like an excellent idea. I appreciate your guidance on this. It doesn't sound too difficult going the route you suggested. Thanks for the link. I'm going to contact some hydraulic shops now. I'll keep you posted here as this goes on. Thanks Mike 69440
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
2008 Chevrolet Impala 50th Anniversary Sedan (A51694)
2008 Chevrolet...
2021 John Deere C450 (A50120)
2021 John Deere...
2003 Honda Element SUV (A50324)
2003 Honda Element...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
2023 John Deere FC 15R (A50120)
2023 John Deere FC...
