Max 26 XL electrical / glow plug controller issue
   / Max 26 XL electrical / glow plug controller issue #1
Cramby
Galesburg MI
Mahindra Max 26XL TLBMMM
My tractor has started giving me trouble after 8 yrs of no problems. The glow plug controller buzzes, dash go dim, then go out, results in a no start. Disconnect battery and re- connect, power comes back and starts, most of the time. Anyone else has these symptoms?
   / Max 26 XL electrical / glow plug controller issue #2
Could be many things, but sounds like a bad connection at the frame ground or battery post. Clean all those good and see if it continues.
Will do.
   / Max 26 XL electrical / glow plug controller issue #4
sounds more like a connection issue. I pretty sure that the controller and the dash lights are on 2 totally different circuits. I would check all connections carefully & closely including the power wire that feeds the fuses
Thank you will check all and report back.
I installed a battery disconnect a few years ago. I found it's internal switch failed. Problem solved.
   / Max 26 XL electrical / glow plug controller issue #7
I would start buy checking wires to the ignition switch and the switch itself or a pinched wire going to the glow plugs.
2016 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A43004)
2016 FREIGHTLINER...
2008 Ford F-550 Truck, VIN # 1FDAX56R18EC89225 (A44391)
2008 Ford F-550...
2018 INTERNATIONAL RH613 DAY CAB (A45046)
2018 INTERNATIONAL...
2016 Western Star Trucks 4700 Truck, VIN # 5KJJAVDV1GPHN4228 (A44391)
2016 Western Star...
2023 AGT Topcat Stump Grinder (A44391)
2023 AGT Topcat...
2012 Jeep Wrangler Unlimited Sahara (MPV), VIN # 1C4HJWEG6CL160900 (A44391)
2012 Jeep Wrangler...
