Max 28 Box Scrape
   / Max 28 Box Scrape #11
54" is ideal but not too many guys stock that size, most guys go with a 60" box. If you have tire spin with the 60", you might load your rear tires.
I use mine with 4x4 engaged and have caught a root and was stopped instantly. Tractor was still trying to go, but lost traction. I think that loading the rear tires may be something I need to consider.
   / Max 28 Box Scrape #12
Many dealers will not sell you a tractor with a loader unless the rear tires are filled. Fill them and you will be amazed at the difference.
   / Max 28 Box Scrape #13
mike69440, I think that you will be much better off staying with a 60" unit. I know that a 6 footer sounds good, but you need to look at things realistically and I sure don't see a 6 foot box blade as being a good match for your 28XL.
Just my :2cents:
I've owned the Landpride since 2005, I won't be ripping, just grading. i figure It will work as long as I don't fully load up the box. I als have a 7' York rake that my B7200 realy struggles with if I try to move a lot of dirt.
   / Max 28 Box Scrape #14
Id be running a 4ft box on that tractor if your really wanting to load it up with dirt
   / Max 28 Box Scrape #15
You ought to be fine. You obviously have a lot of operator experience. A careful operator can often run larger implements than we would suggest to the average guy. We try to keep people out of trouble.
   / Max 28 Box Scrape #16
I am going to try my 6' on my 26xl. Like you I won't use the rippers or fill the box. I will just use it to grade. If I need to use the rippers I'll put it on my big tractor.
2023 Icon I40L Electric Cart (A50324)
2023 Icon I40L...
2008 FREIGHTLINER B2 BUS CHASSIS (A52576)
2008 FREIGHTLINER...
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
2018 BOBCAT T590 SKID STEER (A51246)
2018 BOBCAT T590...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
