max 28 tooth bar
   / max 28 tooth bar #11
As the bucket does not have a repalceable edge a WL Long bolt on would work.
On you Max 28, What tasks have you been able to do with it with the new toothbar?
   / max 28 tooth bar #12
The tooth bar that you are asking about is the traditional one. It has several long Teeth that are spread out the width of it.
Tasks I have used it for
digging/scooping - helps to break up the ground with clay soils. Will add to your bucket capacity if you scoop mulch (works really well)
used it as a hoist - Probably not supposed to; but a chain/strap around a tooth lifted implement's such as tillers and mowers from trailer. awkward car parts like axles and engines it will move as well.
Firewood - when we get a bucket full to tote to the house my son uses those teeth to get just a bit more in that bucket.
It is a tool that in my opinion adds to the functionality of ones tractor and can reduce wear on it by breaking up the surface area on a bucket when digging/scooping. You will not regret installing it on yours, I have yet to hear anyone wish they didn't purchase this great attachment.
   / max 28 tooth bar #13
I purchased the Tractor Supply tooth bar and found it very useful
   / max 28 tooth bar #14
Mikemahindrah... I see no toothbar listed on the TSC website. Any more info?
They DO carry Ratchet Rakes, which are a great tool for a variety of tasks. John32369, you'd really enjoy that, if you have any clearing or brushwork to do.
I have the Piranha toothbar, and it's great for cutting into gravel, mulch or stone; removing brush and small trees, etc. I have found that I need to pull it off
when attaching the Ratchet Rake though, because it does not seat well, because there are so many support wedges on the Piranha, so the Ratchet won't seat squarely.
Paul
   / max 28 tooth bar #15
Paul,
Yes your correct. That is what I have. Thanks for correcting me.
Mike
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
378811 (A51573)
378811 (A51573)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
