Maybe a little too much weight?
   / Maybe a little too much weight? #12
You've got the "before" photo now... all you need is a gooseneck, same load and the "after" photo... would be convincing in the bumper vs gooseneck trailer threads:thumbsup:
   / Maybe a little too much weight? #13
Not only is it a bumper pull, but it looks like it is an actual pintle hitch trailer. The weight distribution is way too tongue heavy on most pintle hitch trailers for a light duty truck.
   / Maybe a little too much weight? #14
When I weighed on the way out, I was just under 24K lbs for the weight of everything.
24k? How much does that trailer weigh?
I've picked up a few 6-8k loads of gravel in my little 6x10 dump trailer but the trailer only weighs 1870lbs empty. This is where a short dump trailer shines since it's near impossible to not load directly over the trailer axles.
I'm sure the Cummins didn't mind a little workout! :thumbsup:
24in pin on excavator tooth bucket (A56435)
24in pin on...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2015 Kubota KX91-3S2 Mini Excavator (A55973)
2015 Kubota...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2021 Caterpillar XQ125 125kVA Towable Diesel Generator (A55973)
2021 Caterpillar...
