Maybe a Water Wheel? Punch plastic mulch
   / Maybe a Water Wheel? Punch plastic mulch #1
chuckcoug
B7800
I want to know the best way to put seeds{Corn} and Transplants{Tomatoes, Melons, Squash} thru plastic mulch?
What do you use?
I think a Water Wheel might be the cheapest way, but after the hole is planted and you drop the transplant or seed in the hole, HOW DO YOU COVER IT?
Thanks
Chuck
   / Maybe a Water Wheel? Punch plastic mulch #2
Most people cut a slit or a cross-slit in the plastic, about 4-6", enough to put seed/plant in and fingers to push soil around.
Could use a scoopful of sand or sterilized potting soil to put in around or over the seed/plant. This would cut down on damping off disease problems, too.
You'll need a soaker hose or other water distributor underneath the plastic. A Master Gardener friend told me of a tool that VaStateUniv was demonstrating that lay down plastic mulch with a drip line beneath it and put soil over the edges of the mulch along each raised row. He said he'd send me info on where/when they do these demos.
Ralph
Ya, They are called Bedders and Mulch Layers. They come individual or can be put together. I am looking at purchasing one from Buckeye. Other companies include Holland, Mechanical Transplanters, etc. If you look really careful at the pictures you can make one very easily. It just a matter of your time. I would make it, but I just don't have the time.
Anyway, here is the website for buckeye>>> www.buctraco.com/index.html
Also you can look at www.marketfarm.com they are a distributor.
I hope this helps. /forums/images/graemlins/smile.gif
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
New Holland 55 Pull Type Rake (A51573)
New Holland 55...
2015 FORD F-550 SUPER DUTY (A52472)
2015 FORD F-550...
