Maybe we should have gotten a crankcase heater in the L3940!
   / Maybe we should have gotten a crankcase heater in the L3940! #11
What are you using for diesel fuel? Are you waiting until the glow plug light goes out? Does it have any antigel in it?
Since the fuel I got last spring was questionable as to if it had anything in it I put the last of the CRC antigel into my 4240. My garage is uninsulated and I have started it easily at temps in the low 20s. I did get a block heater dealer installed but I haven't even looked for the plug yet. Like Phillip said, a little smoke and knock for a few seconds then clears right up. I bet I haven't had to turn it over for more than 5 to 10 seconds before it fires up.
   / Maybe we should have gotten a crankcase heater in the L3940! #12
I think KWentling called it right. At low temps, your battery output is already reduced, then you fire up with glow plugs and thick oil, takes a lot of amps to start it. Only running 15 minutes, unless you're running at near wide open throttle, the alternator possibly just can't put enough amps back in the battery.
pause...sorry but albert King and SRV are on PBS in a tape of them recording texas Flood together. Amazing... sure do miss that man.
   / Maybe we should have gotten a crankcase heater in the L3940! #13
(1)With your short run time, my vote is for the battery tender plus which is temperature compensated. Battery Tender - Home of the Battery Tender Jr. - Batterytender.com
The Jr or other fully auto tenders are fine and will save you some money but IMHO the 'plus' is the best.
(2)Consider going to full synthetic. I now use it in the tractor , my generator and my diesel pickup which all need to start in the coldest of times.
Make sure you don't have a voltage leak either from the Kubota or via something you may have added to it.
My Kubota arrived in the spring of 05 and is still on it's original battery at 550hrs. I am waiting for my first battery tender to arrive, as I realize I am pushing my luck with this battery. I also just put synthetic in the tractor for the first time also.
I have the block heater but only use it on extreme cold days when I remember to do so and don't leave the tractor too far from an outlet. The tractor has always started regardless of being as much as below -30F without the block heater. The tractor is kept outside 365. I usually run it for well over an hour in the winter (plowing).....
Good luck
   / Maybe we should have gotten a crankcase heater in the L3940! #14
I've also seen it suggested elsewhere to keep the glow plugs burning for a few seconds even after the engine starts.
I've tried this a few times and it does seem to rid the rough running a little quicker than just letting the glow plugs go out as soon as the engine starts. Not that it will help the issue with slow turning over in cold weather, but it will smooth the motor out just a tad quicker after a cold weather start.
   / Maybe we should have gotten a crankcase heater in the L3940! #15
QUOTE]
That is not an option on the Grand Lxx40 series. The glow plugs are on a start timer activated by the key. You could cycle the key 2 or 3 times before you attemp to start. Electronic engines like the Cat C7 and Cummins QSB6.7 do this with their grid heaters, but it is part of the ECU programming. After start, they will energize the grid heater while the engine is in cold start mode. One thing I noticed on my L3940, at engine idle, the alternator is not charging the battery. The rpm's need to be at 1200 for the alternator to start charging. In winter time, I start tractor, let idle for a couple minutes, then increase rpm to 1200 and let it finish warming up. Philip.
   / Maybe we should have gotten a crankcase heater in the L3940! #16
I would second earlier suggestion about battery tender...it sounds like you have easy access to electricity, so it is the quickest, easiest thing to try first...install permanently and plug it in every time. If it works, you've found a problem and a solution.
If it works you might suspect the battery, which can be tested ...if you run a big electrical load you might want to swap out for a larger alternator.
Other quick fix is oil change to winter synthetic. If that makes a big improvement, chances are you are never letting engine run at operating temp for long periods ...water condenses in oil, never is boiled out and makes the oil mushy at below freezing temps ...if short trips are the nature of your use, consider shortening the time between oil changes. Of course, block heater would improve things and is probably a good investment, but even so, I would install battery tender.
Slow cranking is either battery/charging-system, starter, and/or viscous oil
   / Maybe we should have gotten a crankcase heater in the L3940! #17
I certainly agree with most of the posts. Battery blanket makes all the difference in the world although you might question the battery itself. In our region we get about 4 to 5 years out of a battery, then the reserve seems not to be there.
Block heaters are pretty standard in Canada. In cars they are generally recommended when it reaches about 10F. In my 3940 (my first winter with it), I've been plugging in for at least 2 hours once the temperature is below 20.
I have cycled the glow plugs a few times if it is below 30, it seems to start better. I presume the glow plug is smart enough to know when the cylinders are too warm.
My last tractor I used a synthetic 0W30 motor oil. I've gone back to the recommended oils only, I've concluded the motor is too expensive to screwup.
The circulating block heater is very easy to install - we used it in the last tractor. If you have a cab the heater will be warm immdeiately.
Garth
Well I'm still trying to digest all this. Today only made it to 31 degrees but I looked at the thermometer in the equipment shed and it was on 48, this at 2 pm. It's still turning over pretty sluggish. I might video it starting tomorrow. I'm thinking it's probably the run time. In the spring and summer she always turns it off at least twice while feeding and it's probably taking a toll on the battery. This is her second winter feeding round bales, last year she used the 574 which doesn't have glow plugs or ether and she didn't have much of a problem. On the days that got down around 10 she really had to play with that weird start/run/stop lever thing it has. I have a good volt meter and I'm going to take some readings. If the alternator isn't up to snuff I'll call the dealer and see what he says.
BTW: She's definitely waiting for the glow plug light to go out, I made sure of that. She's pretty efficient at operating all this stuff, she's been on and around farm equipment for over 40 years.
   / Maybe we should have gotten a crankcase heater in the L3940! #19
You do know that a diesel engine is huge HEAT SINK dont you?
If your alternator belt is loose thats most if not all your problem;
If it has more than an eighth of an inch of slop................... and depending on the belts condition it may be bad and turning to powder due to the slop and excess wear further you dont need to shut it off while feeding just set it at idle and set the brakes.
The very second that the first cylinder that is in the firing order explodes its ration of fuel the rest wil follow simply due to the power generated by the first cylinders exploding the measure of fuel.
Check your alternator belt before anything else. Then remove the battery if the belt is tight, charge it overnight on a low charge rate, and then take it some where to have it tested with a load tester; It acts like you just might have a broken cell that makes contact and breaks contact.
A kerosene salamander is a diesel tractors best friend. twenty minutes after ignition the engine and cooling system will be near operating temperature, the engine oil will be warm and it will just purr when you start it.
( all that is needed is an heavy duty timer that the salamander is plugged into to heat the tractor and you will add years to its service life even in summer when its left overnight that engine is cold and the oil is cold so its behind the eight ball even in the warm months.
The problem with all internal combustion engines is simply one of no oil in the galleries when the engine is cranked and thats the biggest contributor to engine wear especially if the engine oil is cold.
several models of engine oil pumps are offered which pump the oil in the crankcase through the engine prior to ignition sequence.
   / Maybe we should have gotten a crankcase heater in the L3940! #20
If it's 48 in your shed and it's turning over slowly you have a problem. I would check the belt like Leonz said. I would check the battery terminals make sure they are clean and tight. I would also check the line going to the starter. After that I would start it up and use a multimeter to measure the voltage across the battery. You should see somewhere near 15 volts.
If you are in need of a battery charger I have a Schumacher Speed Charge.
This is a great charger and it will test your charging system. Then if nothing else I would call the dealer since any problem should be covered under warranty.
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
Kubota Utility Cart (A59228)
Kubota Utility...
1983 Ford 8000 Tandem Grain Truck (A59814)
1983 Ford 8000...
2018 Bobcat S70 (A55272)
2018 Bobcat S70...
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
New/Unused 7ft Work Bench (A57454)
New/Unused 7ft...
