McCormick Carb Issues
   / McCormick Carb Issues
I didn't change the shafts. The float is origional but is square and has no leaks. I put new gaskets on the shaft from the governer to the throttle butterfly. Starter fluid test confirmed that there are no leaks at any of the connections. When I put my hand over the intake of the carb, theres lots of vacuum. The metering nozzle and gasket was changed.
   / McCormick Carb Issues #12
Talked to Dan today. He said he gots it running for a few minutes but needed the choke on to stay running. Just thought I would give a update.
That's true. But even then it wouldn't run for more than a few minutes. I found a way to keep it running, I use a clean 2x4 and block off the intake of the carb which forces it to only draw air through the vent right beside the load adjustment. If I do this it will run but only at one speed because of the lack of air. I'm still very confused as to what could be causing this problem because I know I've got sufficient vacuum pressure. I bought another carb for it and it should be here sometime next week. I'll keep you updated
   / McCormick Carb Issues #14
Talked to Dan. He got a new carb and it is now running.
2016 Komatsu PC1250LC-8 Hydraulic Excavator (A50322)
2016 Komatsu...
Case SR240 Skid Steer Loader (A50514)
Case SR240 Skid...
Ford F-450 Utility Truck (A52128)
Ford F-450 Utility...
2010 KMC 3376 Peanut Combine (A52128)
2010 KMC 3376...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
6-Row Rolling Cultivator Narrow INOPERABLE/PARTS ONLY (A52128)
6-Row Rolling...
