McCormick Deering crawler advice
   / McCormick Deering crawler advice #11
I'm not sure what your intentions are, once you get it running, but the undercarriage doesn't look too bad, considering.
The bottom rollers have plenty of edge left, so it's not like it should walk off the rails, if on a slope. If it had a blade, you could check the bearing condition by raising it up, and kinda' try to pry up on them. You could probably still do it with a pry bar, and block. Just lightly pry up on the lip of the roller, and see if there is any slop. I notice it has the button head zerks on it. So you may want to be looking around the shop for one, or, he may have dedicated a grease gun with this head.
The rails don't look too bad. At least the bottom rollers haven't appeared to made contact with the pin area. Looks like the adjuster is run out quite a ways... Not sure how that adjuster works. All I've dealt with, the yoke was attached directly to the hub axle. That one appears to rock forward.
The sprocket doesn't look too bad, but hard to tell in the picture. The more they are worn, the sharper the points are. Blunt on the ends, if any, is good...
You can reach between the rails, and feel the pins. You should feel some wear on the back side. If they have been turned, you will feel wear on front, and back sides of the pins...
If the tracks ever need to be separated, it is a job. But don't think you'll need to worry about that for a while...
You may want to check out the link to Red Power Magazine. Then look under the Construction thread. Search for T20, there appears to be more than I imagined there would be, that have them. I'm sure those guys will lead you in the right direction.
That is a great idea to take lots of pictures, before disassembly. If you have a CD burner, or another way to save the pictures, for an extended period of time... Get a virus that ruins your pics, and you've lost them.. Trust me on that one..., LOL..
Keep us updated..!!
I really have no plans for it, or even a purpose. I have a small piece of property (5 acres) as a toy farm: Fruit trees, garden crops, and so forth. I have wheeled tractors to do all of that work, and don't even have any implements that the crawler could pull. I just have fond memories of chugging and clanking along, and was toying with the idea of making it functional in that way again. I'm going to get it there, if I'm able, but want to gather information first. I'll definitely subscribe to the Red Power group. Any other information or leads on things are welcome, too. Thanks for the advice!
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52706)
KNOW BEFORE YOU...
2025 CATERPILLAR 275 SKID STEER (A52705)
2025 CATERPILLAR...
MURRAY PUSH MOWER (A53843)
MURRAY PUSH MOWER...
MOBILE OFFICE CONTAINER (A53843)
MOBILE OFFICE...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
