Mesquite Grubbing suggestions
   / Mesquite Grubbing suggestions #1
RanchMan
Platinum Member
Texas
Mahindra 4110
I have several acres of mesquite I need to remove. (Most is 5" or less in diameter.) I've seen attachments like <A target="_blank" HREF=http://www.dallasweb.com/jones/>this one</A> but wonder how well they work (I have a 40 hp tractor.) 'Course there's the whole thing about getting them cut down before hand (Don't think I'm going to even attempt to cut down acres of mesquite with a chainsaw!) so that brings in a whole other question.
I could always rent a dozer, but would like to do things "on the cheap" if possible. Anyway, what have you guys had luck with when it comes to cutting down/grubbing mesquite?
   / Mesquite Grubbing suggestions #2
Looks like an interesting piece of equipment. I would be curious as to their mim. H.P. recomendation
   / Mesquite Grubbing suggestions #3
Back in the dark ages we used to pour kerosene around the base of the mesquite tree to kill it and then pull them up. They were dead and stayed dead!
Is this against the EPA rules now?
   / Mesquite Grubbing suggestions #4
I've heard of Mesquite before but never worked with it. By the sounds it must be pretty hard stuff. The link you showed look very interesting. I'm not sure if you can shear the Mesquite trees but here is a link to a tree <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=implement&Number=184525&page=&view=&sb=&o=&vc=1>shearer discussion</A>.
If I guessed wrong about the Mesquite tree let me now!
I think the 18" model is rated for a minimum of 35 Hp or so (I'd have to check their ad in my Co-Op magazine I get to confirm though.) Unfortunately unless you get the roots, mesquite will come back even if you wack down the tree flush with the ground - same thing with fire - it'll look dead and come back. Good for BBQ, but a pain to deal with if it is growing where you don't want it. Unfortunately they spread quickly due to animal activity as well (they eat the seed pods and "deposit" them in other places.) I kindof think as mesquite as the feral hog of the plant world. /w3tcompact/icons/sad.gif
With the number of mesquite trees I have, I'm afraid the kerosene method, while potentially successful, wouldn't be something I'd do mainly because I'm talking about hundreds of trees. (A gallon or 2 here or there doesn't bother me much, but I'd hate to put more than that on my place.) I'm not opposed to herbicides per se, but unfortunately due to the runoff patterns on my place and the volume of trees I have to deal with, I'm a bit weary of going that route as well.
I'm afraid I'm looking at dozer time (e.g. $$$). /w3tcompact/icons/sad.gif It works and is used relatively often around here, but just would prefer to minimize expenses while actually being able to do it in a short time frame.
   / Mesquite Grubbing suggestions #6
Mesquite, such a wonderful tree. It will grow where nothing else will, and cutting it down won't kill it. /w3tcompact/icons/shocked.gif I had an acre and a half of mesquites, I cut down about 40 of them and left 12 standing. Since Texas tends to look somewhat barren, I left some trees for relief and mowed around them. Unfortunately, I kept mowing down saplings every week from the trees that I had aleady cut down. That's impressive. I bet it took almost two years for those roots to die. Torching them sounds like a good idea to me.
   / Mesquite Grubbing suggestions #7
I wonder if I could get them to grow here in Georgia. I'd love to have a continuous source for BBQ./w3tcompact/icons/smile.gif
   / Mesquite Grubbing suggestions #8
I think they would survive in Georgia, but I forgot to mention the thorns. I have encountered a couple of diffent types of trees in the mesquite family. The worst are the one's with the blood red thorns, the are as sharp as a needle and are up to 3" long. It seems like they almost jump out of the tree to cut you. The standard mesquite has one inch long grey thorns. THEY WILL GET IN YOUR TIRES. The best advice I can give you, is to leave the thron in the tire. If you pull the thorns out, you will need to plug/patch the tire. My old Ariens probably had a dozen thorns in each tire, combined with some tire sealent they held pressure no problem. Pull the thorn out and the hole is too big for the sealent. Since the thorns have such a fine point, they continually expand until you reach their base.
A Georgian wanting to grow mesquite for grill flavor is like a Texan wanting Kudzu for some greenery. /w3tcompact/icons/laugh.gif
   / Mesquite Grubbing suggestions #9
The easiest method of preventing mesquite ( or other species for that matter) from resprouting from the stump is to cut the tree and them immediately afterwards spray the stump with a labeled herbicide such as Garlon, ect... Just put some dye in with your herbicide mix so that you can see what stump has been treated. Very little herbicide is used by treating in this manner and it's very safe if you follow the label instructions. The key to treating stumps is to spray the stumps right after cutting, before they seal up. That way, the herbicide goes right to the roots.
Hmmm. /w3tcompact/icons/hmm.gif That sounds like an interesting option! I have to admit I'm not very educated when it comes to types / use of herbicides. You mentioned Garlon - Is it (or other equivalent) "available to the public" or do I need to go thru a class/get licensed for it?
2023 ATC Enclosed Trailer w/ Title (A47809)
2023 ATC Enclosed...
1979 Miller 28' Tomato Trailer (A44502)
1979 Miller 28'...
2021 RANCO ANVIL END DUMP (A47001)
2021 RANCO ANVIL...
LGMG AS4046E 40 SCISSOR LIFT (A47001)
LGMG AS4046E 40...
Hydraulic Crane Lift (A47809)
Hydraulic Crane...
2003 INTERNATIONAL 4300 CAB AND CHASSIS (A43005)
2003 INTERNATIONAL...
