Metal in Hydraulic fluid 2020
   / Metal in Hydraulic fluid 2020 #11
I do install new bushings anytime I remove the old ones. The reason for not removing them until they are worn, is to prevent wear in the bushing bore in the transmission case. I feel it is worth they extra wear and tear in the bore to get rid of the debris that collects there. The bushings can be removed and installed several times before wear in the case is excessive. Then application of Loctite Bearing Mount works fine to secure the bushings and prevent leaks.
I've already got it all filled up again, but haven't had it out or washed it all off to see how it's doing yet. Hopefully today I'll get everything picked up and up to the power washer. Thanks for the hints on the metal filings, maybe next time I have something apart to drain the trans oil I'll get into that. Thanks for the help.
UNUSED RAYTREE RMLL60-60" POWER RAKE LAND LEVELER (A51248)
UNUSED RAYTREE...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
