Metal Piece Found in Hydraulic Fluid, Advice Needed
   / Metal Piece Found in Hydraulic Fluid, Advice Needed #11
Yeah, you can learn a lot from taking filters apart, and at least it was ruled out in this case.
   / Metal Piece Found in Hydraulic Fluid, Advice Needed #12
BTW, if a tractor if this age continues to run/work OK with only rare/occasional/minor glitches, I'd leave things alone. A pre-emptive teardown might only make sense if you have the time/interest and there is some evidence of where to look and what to look for. Otherwise it could be a needle (ring?) in a haystack and you might cause more problems than you would fix.
   / Metal Piece Found in Hydraulic Fluid, Advice Needed #13
Personally I'd wait and see if problems develop. I guarantee if you split the tractor you'll be buying more than a retaining ring.
Yeah, I almost have it back together. Replaced the main wiring harness and some other minor work. Picking up some LED lights to mount to the tractor as well. Then I'll fire it up and see what happens. I think I'll take mcfarmall's and s219's advice and wait. If she taps out I will have to get at it, or sign the papers for something new(er). I appreciate everyone's input.
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53472)
NEW 2024 LOAD...
New/Unused 72in Quick Attach Skid Steer Mulcher (A51573)
New/Unused 72in...
