Metal Pieces in sump on JD 4310 During Hydraulic Service
   / Metal Pieces in sump on JD 4310 During Hydraulic Service #11
Because the op has the rear pto cover off the sump is already drained. Since removing the rear cover is not that hard of a job I would plan on doing it in the future. For now I would install some magnets in the sump. The magnets will catch any debris and if strategically placed will show you where any new debris is coming from.
I blew a bearing in the rear cover pto drive train which in turn twisted the spline off of the pto clutch drum. Once I replaced all of the parts I lined up a row of magnets around the oil screen before installing the rear cover. I figured the magnets will catch any debris that I might have missed.
But my statement to need to drain was to check on the screen as mentioned in the comment I replied to! Since the OP found the pieces of metal in the screen housing with a magnetic, yes it is (or was drained) but a future check requires draining again at the time in the future via my response!
   / Metal Pieces in sump on JD 4310 During Hydraulic Service #12
Does the machine have a filter becids the suction side? If so I would attach a few strong magnets to that filter and use it like normal for a few hours then cut open the filter.
   / Metal Pieces in sump on JD 4310 During Hydraulic Service #13
The suction filter is just behind the step on the LH side
The pressure filter is under a plate in the center of the tractor.
   / Metal Pieces in sump on JD 4310 During Hydraulic Service #14
Put a maginet in the fluid somewhere you can easily check/clean it without having to do a complete drain.
That's a good idea, but I'm not really sure where you could do it and have it be reliable. There's a magnetic drain plug on it now that was empty and it was only 10 or 12 inches from where I found the schrapnel deposit.
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
2005 Ford F-650 2,000 Gallon Water Truck (A55788)
2005 Ford F-650...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Hose Reel (A53424)
Hose Reel (A53424)
