MF 1145 oil in water
   / MF 1145 oil in water #1
willapplejack
Bonney Lake,WA
MF 1145
Hello
I am new to tractors, purchased a used Massey/Ferguson 1145 at an auction. It was low on water. When I got it home and filled it with water there is oil in the radiator. After it warmed up, oil came out a tube on the right side of the enginge.
Any ideas as to what is cause. ?
Is this a common failure of this engine. ?
Iseki E3AD1
   / MF 1145 oil in water #2
It sounds like a "blown " head gasket. Don't run . Water in engine = expensive repair. Check engine oil level, the radiator is probably draining into the engine, so level will be way high. I would get a mechanic to have a look at your level of inexperience.
   / MF 1145 oil in water #3
oil in the radiator.......this must be your clew ~ Oilpressure will press oil in the watersisteem . Where is the oil next to the water ?
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2016 FORD TRANSIT T250 CARGO VAN (A57880)
2016 FORD TRANSIT...
2019 CHEVROLET SILVERADO 11FT FLATBED (A57880)
2019 CHEVROLET...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2012 FREIGHTLINER...
