3-Point Hitch MF 1250--adding top tilt to 3 point hitch
   / MF 1250--adding top tilt to 3 point hitch #1
mgtd
Any advice or experience on adding top tilt to 3 point on my 2003 MF 1250. Can't really see the valve and or hosing until I pull the right rear wheel. Just wondering if anyone could tell me if I'll find a Pwr Beyond port on the existing loader valve or will have to replace the valve.
   / MF 1250--adding top tilt to 3 point hitch #2
Does the loader valve currently have 6 or 7 hoses going to it?
Is the valve mounted on the tractor or on the loader?
If it is mounted on the loader, what brand is the valve?
Just checked my tractor and found the loader valve is a Cross valve mounted on the tractor with 6 hoses (In-Out and 4 work ports) and I found a plugged BYD port. Should be a relatively easy solution to get the correct BYD sleeve and plumb in the triple open center spool valve I already have for operation of the top tilt and side tilt for the 3 point, leaving me another section of the valve for a later grapple. Appreciate the response--it spurred me to take a closer look at the tractor.
   / MF 1250--adding top tilt to 3 point hitch #4
Sounds like your on your way to a tnt.:)
   / MF 1250--adding top tilt to 3 point hitch #5
Okay
Im lost. Also trying to add remote hydraulics on my 1250. Has factory loader installed. Where do I find additional hyd ports, and how do I know if its power beyond?
Thanks,Craig
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
Parker 400 bu Gravity Wagon (A50515)
Parker 400 bu...
2803 (A50460)
2803 (A50460)
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
John Deere Disk Chisel (A50515)
John Deere Disk...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
