3-Point Hitch MF 1250--adding top tilt to 3 point hitch
   / MF 1250--adding top tilt to 3 point hitch #1
mgtd
Any advice or experience on adding top tilt to 3 point on my 2003 MF 1250. Can't really see the valve and or hosing until I pull the right rear wheel. Just wondering if anyone could tell me if I'll find a Pwr Beyond port on the existing loader valve or will have to replace the valve.
   / MF 1250--adding top tilt to 3 point hitch #2
Does the loader valve currently have 6 or 7 hoses going to it?
Is the valve mounted on the tractor or on the loader?
If it is mounted on the loader, what brand is the valve?
Just checked my tractor and found the loader valve is a Cross valve mounted on the tractor with 6 hoses (In-Out and 4 work ports) and I found a plugged BYD port. Should be a relatively easy solution to get the correct BYD sleeve and plumb in the triple open center spool valve I already have for operation of the top tilt and side tilt for the 3 point, leaving me another section of the valve for a later grapple. Appreciate the response--it spurred me to take a closer look at the tractor.
   / MF 1250--adding top tilt to 3 point hitch #4
Sounds like your on your way to a tnt.:)
   / MF 1250--adding top tilt to 3 point hitch #5
Okay
Im lost. Also trying to add remote hydraulics on my 1250. Has factory loader installed. Where do I find additional hyd ports, and how do I know if its power beyond?
Thanks,Craig
(APPROX.52) UNUSED 2X4X16 PRIME GRADE LUMBER (A57192)
(APPROX.52) UNUSED...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
ECHO CS-4920 GAS CHIANSAW (A57192)
ECHO CS-4920 GAS...
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A57193)
UNUSED FUTURE MINI...
2009 MOROOKA MST-2200 VD TRACKED FLATBED DUMPER (A52707)
2009 MOROOKA...
2003 International 4300 S/A Day Cab Truck Tractor (A55852)
2003 International...
