MF 135 Hydraulic Leak?
   / MF 135 Hydraulic Leak?
Since someone asked above, I would say it takes 5-10 minutes to leak down once I shut it off. When I start her up it pops right back up to where it was.
Stuart
   / MF 135 Hydraulic Leak? #12
if a ford will hold up 5m i won't tear into them, unless it has other issues.
if it leaks down in under a minute.. I will tear into them.
   / MF 135 Hydraulic Leak? #13
I have the same tractor and problem. The guy I purchased it from was using some thick gear oil in the case, I flushed it, cleaned it and then refilled with the proper hydrolic fluid. All was fixed.
   / MF 135 Hydraulic Leak? #14
never rely ont he previous owner to have known anything about a machine you buy from them. I always do a full service on all tractors.. just so I know what is what.
many people maintain equipment like it is rented.. put the wrong oil in.. then complain it does not work.. and sell it.
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A53473)
2024 BCL...
2018 JLG 10054 TELESCOPIC FORKLIFT (A51406)
2018 JLG 10054...
Tradewinds Power Unit (A50120)
Tradewinds Power...
Adams 5T High Clearance Fertilizer Spreader (A53473)
Adams 5T High...
