Oil & Fuel MF 135 leaking gas from carburetor into air intake
   / MF 135 leaking gas from carburetor into air intake #11
They did use an oil bath air cleaner but I think they went to a dry air cleaner in later model years.
   / MF 135 leaking gas from carburetor into air intake #12
ovrszd is correct, inline motor updraft carb. If you get enough fuel to leak up into a cylinder you've got some serious issues. I do believe later models used dry element filters. My '64 35 Utility still uses the Donaldson style wet air filter.
   / MF 135 leaking gas from carburetor into air intake #13
it sounds like the float is leaking, take the float out and shake it, if you hear gas sloshing around, replace the float. I solder my own floats, but that's for someone with a lot of soldering experience!..
UNUSED DB500 DUSTLESS BLASTER (A51248)
UNUSED DB500...
2020 JOHN DEERE CP690 LOT IDENTIFIER 190 (A53084)
2020 JOHN DEERE...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
2020 Kinze 3505 High Speed 6/11 Planter (A53472)
2020 Kinze 3505...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
2023 JOHN DEERE XUV590M LOT IDENTIFIER 27 (A53084)
2023 JOHN DEERE...
