MF 135 rear wheel
   / MF 135 rear wheel #11
I Appreciate all the help. Is there a way to patch the rust on the wheel?
Ted
You could dis mount tire, and tube; bronze braze or weld with a welding spoon over the valve stem area, filling the rust and value stem. Grind smooth and prime. Then drill a new valve stem hole at a better area of the rim. Make sure you smooth and deburr the new hole or it can cut into the tube stem.
   / MF 135 rear wheel
Thanks again Kenneth and Paulharvey, for the centers I have, how do I determine which wheel will work for a loop type rim? Do I measure center to center on outer bolt holes where it mounts to wheel?
   / MF 135 rear wheel #13
Yes, the center to center on the outer bolt holes where it mounts to the wheel, (mine measures 20 1/4" center to center with the 24" diameter loop type rims).
   / MF 135 rear wheel
You've been very helpful, thank you.
Ted
   / MF 135 rear wheel #15
Your tire repair guy may block the rusted hole in the rim and drill you a new one, then patch or replace the tube and put the fluid back in. A total bill of about $100 wouldn't be too bad.
   / MF 135 rear wheel #16
Put a tube in it and be done with it.
   / MF 135 rear wheel
Sounds like a great plan to me, that's what I'm going to do.
Thanks for all the help.
Ted
   / MF 135 rear wheel #19
A welder can fix them. I've had it done. On the valve stem hole a plate with a hole drilled in it was welded in and then ground smooth. This on a tubed tire.
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
12" x 16.5" Kubota RTV-X1140 Tires (A52377)
12" x 16.5" Kubota...
2803 (A50460)
2803 (A50460)
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
