MF 165 fuel lines
/ MF 165 fuel lines #1
Sean165
Greer, sc
MF 165
In my hast to have the injector pump rebuilt - I did not mark where the two fuel lines from the pump go ( I know back to the fuel filter) , but which outlet. There are two places on the filter marked with arrows ( one pointing in and the other pointing out). From the pump - the end where the injector lines are coming out - there is a fuel line - does that return fuel or bring fuel
/ MF 165 fuel lines #2
The arrows indicate the floow direction. In other words. From the fuel tank to injectors or carb, the arrows should go with the flow. :thumbsup:
/ MF 165 fuel lines #3
Fuel line connection at drive end of pump is return back to filter base, pump inlet next to injector line banjos line is connected to filter base outlet arrow.
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
HYDRAULIC AUXILIARY TRANSMISSION (A60736)
HYDRAULIC...
1987 INGERSOLL RAND PT-125R PNEUMATIC ROLLER (A62129)
1987 INGERSOLL...
2012 Toyota Camry Sedan (A61569)
2012 Toyota Camry...
2016 Ford F-150 Ext. Cab Pickup Truck (A61568)
2016 Ford F-150...
