3-Point Hitch MF 165 hydraulic arms all up or all down nothing in middle
   / MF 165 hydraulic arms all up or all down nothing in middle #1
desross
Helensville
mf 165
Is there an adjustment as my arms have no middle ground its all up or all down. cant get anything in the middle at all
any thoughts on where to start looking
cheers
des
   / MF 165 hydraulic arms all up or all down nothing in middle #2
To control the height on the arms you use the inside lever (position control) .
The outside lever is draft control and should be in the fully up/back position at all times. It is only used for ploughing.
Which one are you using?
What year is your tractor, there are 2 types of control layout?
   / MF 165 hydraulic arms all up or all down nothing in middle #3
Also did this start all of a sudden or has it been a chronic slow growing issue for a long time ? My first guess is air in the system somewhere. Plenty of hydraulic fluid in it ? Might suck air if low on fluid. I gather from it being a MF 165 it probably has some age and possibly high hours on it. If so, that could be many grungy things I don't want to think about -- seals, the lift control valve, etc.
Good luck with it and let us know the outcome.
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
