MF 188 engage pto problem
   / MF 188 engage pto problem #1
kostaschatzis
GREECE / ORESTIADA
MF 188 / FIAT 880-5
Hello everyone, a few days ago I bought a mf 188 (1979 not multi power) when i m trying to engage the PTO (tractor stopped)
A) whith PTO shaft , it is difficult to engage the PTO (hard noise)
B) without the pto shaft it is engage very easy,
C) if i select pto on rear axels it is engage very easy, but i want it to take power from the engine .
D) With the engine off it is ok, engage and work (it seems that the cluch does not stops the pto)
1st time MF owner my other tractor is FIAT 880-5
Thanks in advance for the answers
   / MF 188 engage pto problem #2
Hi and Welcome. You have a very capable tractor - the type I wanted when I was a boy .... and these 100-series models were new!
A couple things to check :
Are you sure the clutch is pressed all the way to the footrest, so the second stage is released? This is what allows PTO engagement.
Otherwise the clutch linkage - quite easy - or the second stage release - quite an involved job - needs adjustment.
Good luck!
Thanks for kind answer but from many tries only once i ve made to engage without any noise. the strange is that when there is nothing on 3points attached and its free then the PTO engages very easy and nice . then whith the pto shaft on and a sprayer cant lock it. I ve already change the bold nr 30 (on foto) and the clutch came very high but nothing happens . maybe i was very nervus , i ll try tomorrow again .Sorry for my ENG and Inkedclu_LI.jpg Thanks for your reply!!
   / MF 188 engage pto problem #4
Do you have the right free play on the pedal?
Good evening Agvg!Probably you are expert according to the nr of posts ,
Sorry for my ENG but what do you mean by right free play ?
I post that also on MF owning /operating file , there also Mr DLTTrekkers send some advices what to do, but here seems that everyone want to help , probably i found good people, i m 1st time owner of MF i have a FIAT 880-5 and now i m trying to learn MF188 , Thanks for the reply!! can you explain me the right free play? do you mean how cm goes theclutchpedal when i press it by foot without nothing happen? Thanks for your interest Agvg!
   / MF 188 engage pto problem #6
The free play is how many cm the pedal goes down with no recistance.
Thanks again Agvg , it very kind to reply and giving me advices ,on monday i l try to fix it (not alone) following the advices of mr DLTtrekker, anyway . I would like to thank you for your support and interrest, maybe i ll ask you again if i cant fix it.
Have a nice day
2012 Dodge Charger Sedan (A55853)
2012 Dodge Charger...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
UNUSED IRANCH 8" MINI EXCAVATOR BUCKET (A57193)
UNUSED IRANCH 8"...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
CFG Industrial MX15RX (A56469)
CFG Industrial...
