MF 231S not charging
   / MF 231S not charging #1
fireman4074
MF 231S
I have MF 231S. I took old alternator to repair shop but he said that it would be cheaper to get new one. I put new alternator on it and it’s still not charging. I took one of battery terminal off while cranked and motor died. What else could be the issue with charging? I think that read somewhere about it could be oil sensor. How do I check that?
   / MF 231S not charging #2
You might take the new alternator to the repair shop to see if it is functional. New and functional are not the same thing. You could then ask why it does not seem to be working if it checks out okay.
   / MF 231S not charging #3
Does the "lightning bolt" red light come on? I had a charging issue on the similar 240 and it was solely because the light was burned out in the dash. Replaced bulb and it worked.
2022 JOHN DEERE 330G SKID STEER (A52705)
2022 JOHN DEERE...
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A55852)
2013 International...
2014 Ford F-150 Ext. Cab Pickup Truck (A55852)
2014 Ford F-150...
Wooden Swing Bench (A55853)
Wooden Swing Bench...
JOHN DEERE 850K LGP CRAWLER DOZER (A52707)
JOHN DEERE 850K...
